Question about Apple iTunes
My windows vista does not recognise my usb ipod shuffle.......?! it was fine before.tried the 5steps...the pc still does not reconginise it.
  • 11 Answers
In 1 line:uninstalled the iPod firmware updater program and iTunes. Get a fresh download of the firmware app and iTunes .Try installing iTunes 4.7.1
Steps:
remove the iTunes software and iPod drivers, make sure the iPod isn't connected. Restart the computer and reinstall the software again.
When you log in, load up iTunes (wait till it's fully opened and not in a busy state)
Then connect your iPod.
Posted on May 13, 2009
    Problem Solver:
  • 7 Answers
Try other usb items like flash drives. do they work ? if yes. there is no problem with your vista configuration. the problem is on ipod shuffle... then try on say win xp .. if the ipod works fine. .then you need to install some sort of driver for your ipod shuffle. hope this helps.
6ya staff
SOURCE:
My ipod shuffle 2nd generation does not mount as a disk drive my pc sees it as an unknown device therefore it will not be recognised by itunes how do i get music on my new ipod shuffle??
Is it new?
On the iphone if you hold (and keep holding) the home button as you connect both ends of the firewire/usb this triggers a complete reinstall, without needing to connect to Itunes.
Feb 22, 2010 | Apple iPod shuffle Second Gen. Silver (1...
Ipod shuffle 512mb problem
please try to re install the drivers of your ipod on your computer and try again
Sep 04, 2008 | Apple iPod shuffle MP3 Player
System Requirements
Hello Bluben,
Your Apple iPod should work just fine with Windows Vista providing you are using the latest version of Quicktime / iTunes.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 10, 2008 | Apple iPod shuffle Second Gen. Silver (1...
IPod shuffle 1st gen. Not Recognized By PC
Try a different USB port first. Here are some other suggestions:
Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
need to be recharged.
â Make sure you have installed the latest iTunes software from
www.apple.com/ipod/start.
â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
inserted only one way.
â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
turn it back on again.
â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
appear in iTunes or the Finder, the battery may be completely discharged. Let
iPod shuffle charge for several minutes to see if it comes back to life.
â Make sure you have the required computer and software. See “If you want to doublecheck
the system requirements” on page 25.
â Try restarting your computer.
â If none of the previous suggestions solves the problem, you might need to restore
iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
repaired. You can arrange for service on the iPod shuffle Service & Support website at
www.apple.com/support/ipodshuffle/service.
Jun 09, 2008 | Apple iPod shuffle MP3 Player
Ipod shuffle
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Apr 24, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod shuffle 2nd gen
there could be a problem with your usb port...try another port or try another device in same port...also could be the connecting cable for ipod....
Jan 01, 2008 | Apple iPod shuffle Second Gen. Silver (1...
IPod shuffle Second Gen problem
Apple recommends that iTunes customers using Windows Vista upgrade to iTunes 7.2 or later. If you are using an iPod with iTunes on Windows Vista, please review the important information in Knowledge Base document
Ejecting iPod using Windows Explorer on Windows Vista may corrupt iPod
Issue
Some customers may see the following message when connecting an iPod to iTunes 7.2 or later on a computer running Windows Vista.
Solution
Microsoft has released an update for Windows Vista that addresses a situation where ejecting iPod from Windows Explorer or by using the "Safely Remove Hardware" feature in Windows Vista could corrupt your iPod. Apple recommends Windows Vista customers who own an iPod install this software update. For information on how to install this Microsoft hot fix, refer to the "Update your software" section below. Tip: iPod can always be ejected safely by choosing Eject iPod from the Controls menu within iTunes.
Microsoft has made this Update for Windows Vista (KB936824) available via Windows Update as well as a separate download package. To download this update via Windows Update follow the steps below:
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, select Check for updates in the Security section. If the Control Panel is in Classic view, open Windows Update.
  3. Click the View available updates link and be sure that Update for Windows Vista (KB936824) is checked.
  4. Click Install.
Sep 15, 2007 | Apple iPod shuffle Second Gen. Silver (1...
IPod Shuffle and compatibility with USB ports
yes it's a common problem, it might be a usb 2.0 or high speed usb port but the motherboard is unable to supply enough ampage to supply the port. Assuming you have tried removing other usb connected peripherals and tried a different port, the only way you may get the ipod to connect is to purchase a mains powered usb hub as the power supplied is sufficient to connect to ipods and pda's etc.
Sep 10, 2007 | Apple iPod shuffle MP3 Player
Apple iTunes Logo
272 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
