The two wires come from motor. The black and yellow go inside black box. How do I get the yellow back into box. I dont see any place where I can open black box. Pls help Posted by Angela Browne on Dec 12, 2013 Add Comment
SOURCE: Lakewood HV-18 fan... how to wire switch?
i got the same problem with the wires on this exact switch of the exact fan and aswell 5 to 10 years old heres the type of switch that this fan uses --> any idea? btw im checking the case where the velocitys are marked let me put u the order goes like the this
HIGH_ _ MEDIUM
OFF------ O ------ LOW
http://www.nelsonappliance.com/Lakewood+Switches+for+HV-18+Fan+%7C+HV-12+%7C+P25+Fan.html
My switch unit also fell apart as I took the back off and I didn't get to see the correct position of the switch. After much trial and error, I found this to be the initial "Off" position (see photo)
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
