I have my receiver, direct tv box HR 44-500 and Television set up to all come on when I push watch Tv. Since I changed dirct tv box nothing seems to work.
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
SOURCE: television input doesn't always match activity
Depending on the type of tv you may need to count the TV tuner as an input. My bro-in-law had the same problem. The TV has 5 inputs (S-video, HDMI, etc) but when you set up the remote you need to tell the remote you have 6 inputs, one for the TV tuner.
I hope that helps.
SOURCE: harmony 880 remote will not turn on my dish 622 satellite receiv
Have you tried contacting your dish people, maybe they can reset.
SOURCE: Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue. The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device. And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room. This may require closing a door or drawing heavy drapes closed.
Hi, this is Mary with Dish Network Customer Service. It sounds like you are experiencing a power issue with your Dish network VIP622 DVR. You can try resetting the Receiver box by unplugging it for 10 seconds (if it is plugged into a surge protector, for the purpose of troubleshooting, plug directly into a wall outlet). Wait for receiver to reacquire satellite signal. If you are still having an issue, you will need to contact Dish Network because the receiver box will probably need to be replaced. I hope this information helps you.
