Detailed instructions on how to install multi grove belt on Rikon bandsaw model 10-325.
For the high speed, (2950 ft/min), the belt should be installed on the rear pulley of both the motor and the wheel. For the low speed( 1445 ft/min), the belt should be installed on the front pulley of both the motor and wheel. To properly adjust the belt tension, turn hand wheel until there is 1/2" deflection in the "multi-vee" belt. Check this link to see the manual. http://www.highlandwoodworking.com/library/manuals/10325_manual.pdf
By the way, where do you get your band saw blades? I got mine from sawblade.com and I happy with them.
