Question about Rheem 13PJL30A01-RHLLHM3617JA 2.5 Ton 14 SEER Heat Pump Air Conditioner Split System
The blower starts before its warm and it blows cold air for about 30 sec when its shutting down .
    Filmmaker:
    Uploaded 5 video answers.
  • 22 Answers
When any unit 1st come's on, you'll always have some cold air that's in the ducts that will blow out before you get warm air. If your duct work is uninsulated in a cold basement or crawl space then it will be even more noticeable. When the unit is heating from the Heat Pump mode, it takes a little longer for the gases to get warm enough so you'll fell heat. When it gets cold enough for the unit to switch from heat pump to the gas or electric heat source, you'll get warm air faster. If you have gas heat, some Thermostats have an anticipator setting for the gas valve. If it's set wrong it will effect the on/off cycle of the gas valve.
All duct work in non heated and a/c spaces, including inside walls,above dropped ceilings, in attics and crawl spaces, must be sealed & taped at the seams and joints and then insulated and taped.
Most new construction has solved that problem with insulated duct board, flexible insulated supply's and special tape.
Posted on Dec 12, 2013
6ya staff
SOURCE:
Hi I got a town & country 2006 When the A/C is on it blows nice cold air the after 30 sec to a min it start to blowing hot air. Thank You for your help. John"
First thing to check is the level of the Freon in the system. Probably has 134a in it. Open the hood and look for the air conditioner compressor. When you find it turn on the engine and look at it again to see what parts are turning. Then go turn on the Air conditioner and you should hear the compressor kick on, look at it again to see what new parts are turning and then wait to see what changes when the air gets warm. This is an indication that there is not enough 134a in the system and when the pressure drops on the low side of the compressor it shuts off.
May 05, 2017 | Cars & Trucks
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
I have a 2003 Buick Rendezvous. The drivers side blows hot air and the passenger side blows cold air. The car has that dual zone climate control. I have no clue where to start.
The actuator that 'blends' cold with hot is stuck in the cold position. There are a couple of options. Disconnect the battery, then drive the vehicle around without using the AC for 10 min, if the AC is defaulted to come on after a battery interuption, then shut the car down then turn it on again. You are trying to get the electronic actuator to reset and resume proper function. Another option is to try this: Start the car, adjust the pax side full hot, drivers full cold, wait 30 sec then shut car down, then start car back up and reverse the settings, pax full cold, drivers full hot. In both solutions, the vent actuators are stuck at either the full open or full closed, so you are trying to get it to 'self check' and allow them to resume proper function. After two years, I simply removed them altogether since I live where it is hot an only need cold.works just fine....
Nov 10, 2011 | 2003 Buick Rendezvous
9yr old model Maytag window a/c - just blows cold for 30 seconds - then blows warm. Was perfect until this happened. Is it worth fixing? What would be the usual fix for this?
The compressor is shutting off on overload after running for a few seconds. The overload cools down and starts the compressor running again until the overload heats up and shuts the unit off again.
Aug 02, 2011 | Heating & Cooling
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
2001 ford escort zx2 has no heat. Blower OK, AC fine. I did notice the temp guage fluctuates quite a bit. When I select full hot, will get warm (NOT hot) air for about 30 sec. then it blows cold. Could...
It is much more likely you are low on coolant or you have an air bubble trapped in the cooling system. You should bleed the cooling system to get any trapped air out and make sure it is full of coolant.
Dec 14, 2010 | 2001 Ford Escort ZX2
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
1996 buic park heater starts to heat then afer a minute blow cold
it sounds like you have a blend door problem. This is located in the HVAC sysem it closes a door from cold side to hot side. sounds like a bad servo motor or a vacuum leake on that motor. Hope this helps you, please rank this solution
Jan 18, 2009 | 1996 Buick Park Avenue
Rheem 13PJL30A01-RHLLHM3617JA 2.5 Ton 14 SEER Heat Pump Air Conditioner Split System Logo
153 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
pawnpower
Robert Hunt
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
