Maytag MAH2400A Front Load Washer Logo
S
Sharon Mackenzie Posted on Dec 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mah2400aww door won't open
Door won't open even though it says it's unlocked. there is no error code, and we have tried turning it off and back on again, unplugging it, and redoing the cycle again to see if it will unlock at the end of it
Graham Bagwill
Level 2:
  • Expert 102 Answers
  • Posted on Dec 21, 2013
Graham Bagwill
Expert
Level 2:
Answers
102
Questions
Helped
30281
Points
193
Wax motor (Door lock mechanism) & or control board burn out. Door can be unlocked with nylon string situated in soap power dispencer at front.
  • Anonymous Mar 15, 2017
    I opened my soap power dispencer at the front and I do not see a nylon string. Any ideas how I can unlock the door?
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Oct 20, 2006
SOURCE: I can't unlock the door
fencer, you probably have a bad door lock switch. There was a technical bullitin out by Maytag regarding this (TS740). The deal is that the plunger of the switch is depressed but the contacts don't close. The machine control board senses the door is not locked and won't send the signal to unlock it. You can try to put the machine in the service mode by pressing delicates and heavy soils together for 3 seconds. Advance to the board output tests by then pressing rinse. After that press the max extract key to lock the door and the xtra rinse key to unlock the door. See if it works for you. You may want to call Maytag and inquire about the service bullitin, maybe you can get it covered. There is a manual door release in the dispenser section. The pull tab should be toward the front. You may have to remove the screws and remove the dispensor to get at it. Catriver...post back.
Anonymous
  • 331 Answers
  • Posted on Jul 29, 2007
SOURCE: Door lock
Run a diagnostic on the door lock system; To place the unit in "service mode", close the door completely then press and hold both the "Delicates" and "Heavy Soils" keys for three seconds. Motor speed will be displayed. Press "rinse" to access the main board output function. Then press "max extract"... this is the test for the door lock. Did it lock? To exit, press "max extract" again and then both "Delicates" and "Heavy Soils" for three seconds. VOLTAGE TESTS AHEAD!!! IF YOU AREN'T SURE YOU CAN DO IT, THEN DON'T! CALL A PROFESSIONAL! If the door did not lock, you'll need a voltmeter and an hour or so. Open the door, remove the screws holding the door hinges, then remove the 2 screws (and shims) opposite the door hinges and close the door (do not take it off). Then grasp the front panel at the top near where it meets the top panel and pull toward you quickly. Lean it forward and remove it from the 2 clips at the bottom. Just below the top panel, now exposed, are the top panel retainers... use a 5/16" to remove the one screw on both sides and remove the retainer clips. Now lift the top panel up just like the hood of a car. You can now see the door latch assy. Remove the 2 wires on the solenoid and insert your meter probes into each one of them (color doesn't matter). Set your meter to read AC Voltage, then re-enter "Service Mode" and follow the steps to door lock test. When you hit the "Max Extract" key, 120 volts should be sent to the meter. If you get 120 volts, your latch assy. has failed and should be replaced. If you don't get 120 volts, your control board output has failed and needs to be replaced. Hope this helps.
Anonymous
  • 3587 Answers
  • Posted on Feb 10, 2008
SOURCE: washer door latch stuck, can't open
ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
Anonymous
  • 1314 Answers
  • Posted on Feb 18, 2008
SOURCE: door won't unlock
pull out the dispenser drawer push down on the tab remove the drawer and there is a cord you can pull to unlock the door pull on the door same time you pull the cord
tom weber
  • 198 Answers
  • Posted on Feb 19, 2009
SOURCE: Maytag washer MAH 5500b FL code and door will not unlock.
Open the detergent dispenser door on top of mach. There you will find a small yellow nylon cord, pull on the cord and the door should open
1helpful
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 • Ovens
Doors not opening even if they are unlocked
My 2009 Sebring does the same thing occasionally but only the drivers door gets stuck (dead locked - even though the locks appear to pop up).
The solution I have found once this happens is:
1) The car needs to be driven (crawl in thru the passenger door) -even just a short distance
2) Engine shut off & doors locked with remote (after you've exited from the passenger door of course)
3) Leave turned off for 10 minutes
4) Doors will now open when unlocked with the remote
I have a 2004 G35 coupe and the gas door won't open even though all doors are unlocked
there is a release threw the trunk check the latch after you open it
All my remotes won't unlock passenger doors, why?
this is a problem that can appear after your car battery died, cause the car didn't reset propely, so taking the battery out and putting it back in or letting your car die again would do the trick. I tried a lot of reprogramming procedured for my remote key, none of them worked, what did the trick though was simply unlocking the doors via the all door unlock button on the passenger side door, so simple.
3helpful
2answers
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Hi! My LG washing machine is showing a "de" error code. It won't allow water into the drum. Please help
Hi, the error code "dE" signifies a door open error. This may simply be because the door is not all the way closed. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
1helpful
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • 0helpful
    Doorhandle forced when locked. now it will not open when unlocked
    most likely the door frame is out of alignment due to the force of the weight.
    you can try to open the door from the opposite side. push instead of pull.
    if that doen't work, use a nail and hammer, remove the pins from the hinges pop open the door off the frame. (have someone braced the door before you push it.)
    once you have it open check the alignment of the door frame, and realign it as necessary.
    Door buzzing/not locking
    press cancel. (turns off washer)
    press start/pause (wake up)
    hold cancel and start/pause 10sec
    last error code will come up.
    E47 door lock error
    check wires connections to the door lock..
    replace door lock..
    hope it helps
    Top Maytag Washing Machines Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    ZJ Limited
    ZJ Limited
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
