Samsung SyncMaster 931B 19" LCD Monitor Logo
A
Anonymous Posted on Dec 12, 2013
Can't get the menu to come up or get it off of digital mode
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
The menu in my canon sx10 is camera where the digital zoom is located is not "illuminated" as a menu selection I can pick to turn the digital zoom back on. If I try to pick it from the menu, it...
There are certain modes that you simply can't get digital zoom in (such as widescreen mode). If that isn't the problem, perhaps it's not enabled. According to the manual which I believe is here: http://gdlp01.c-wss.com/gds/7/0300001567/01/PSSX10IS_CUG_EN.pdf on page 54 of the manual (p56 of the PDF) it shows that the digital zoom can be enabled in the FUNC menu (in a record mode). The description of digital zoom, including the safety zone, which might explain why you can't get digital zoom under certain circumstances, is on page 68. Note that there's a big chart on page 286/287 that shows what features are available in each mode - I have a feeling that this could be your problem.
1helpful
How do i change picture size on my coolpix l18
Press the shooting mode button in shooting mode to display the shooting mode selection menu and set the shooting mode to Auto (the green camera). Press MENU to display the shooting menu. Navigate to "Image Mode" if necessary and press OK. Take your pick of sizes here, then press OK to save the change and then MENU to exit the menu.
3helpful
How do I change resolution on my nikon l18
Press the shooting mode button in shooting mode to display the shooting mode menu and set the shooting menu to Auto mode (the green camera). Press MENU to display the shooting menu. Use the arrows to select "Image mode."
1helpful
Audio recording function cannot be switched ON in menu
Check the recording mode you are using. This option is available on Auto, Scene and Macro modes only. To set this, press Menu/Set button to enter the REC mode menu and select the recording option to set.
11helpful
Menu Locked
While in capture mode, hit the green (delete) button.
You can change modes from here. :)
Burst mode
Turn on the power with the mode switch in the camera position. Press MENU to display the menu. Select Mode (REC Mode) menu item with the left & right arrow buttons on the control button. Select the "normal" setting with up/down arrow buttons. Press MENU to turn off the menu. I believe the pictures already taken in burst mode are retained in the camera. Please update the question & let us know if the information given was useful to you - Good Luck!
“My Mode”
My mode allows you to save customized camera settings. My Mode allows you to save different setting configurations. To use the “My Mode” settings, turn the mode dial to the icon shown. The My Mode configuration is selected by the menu selection Mode Menu > Camera > My Mode.
“My Mode”
“My Mode”
My mode allows you to save customized camera settings. My Mode allows you to save different setting configurations. To use the "My Mode" settings, turn the mode dial to the icon shown. The My Mode configuration is selected by the menu selection Mode Menu > Camera > My Mode.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
