Our Bosch does the same thing, we just open the door shut of the power and close the door again so the heat can sanitize the dishes. I don't recall if there is an alert off button though.
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-handCANCEL/DRAIN button, also press and hold the ON/OFF button 2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons 3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent! 4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ).
To Enable or Disable the Cycle Completion Signal...
1. Open the door, hold down the ?Quick Wash?
button and simultaneously turn the Dishwasher on.
The ?Quick Wash? light will blink (program mode).
2. While the light is still blinking, push the ?Quick
Wash? button.
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it
doesn?t beep, it means that the Cycle
Completion Signal has been disabled.
3. Turn the Dishwasher off to take it out of
program mode.
I hope this answer's your question. Thank you for choosing "fixya".
Please rate the solution favorably if indeed it was helpful, if not please let me know.
Good luck.
macmarkus :)
