Question about RCA F32648 32" TV
Rca f32648 My daughter played with the remote and now I cannot get the TV to stay on channel 3 so cable will work. The TV keeps counting dwon from 64 to 2 in increments. When I tried to go into menu it bounces around the options so I can't try to fix it that way. I unplugged the TV for a day. I took the batteries out of the remote and pushed very button. I would love to find help to fix this or reset the TV so it doesn't do this. Thanks
  • holly1977 May 02, 2008
    I have the same problem. It worked fine one day and then the next day it is scrolling between the Guide Plus and the Menu and won't allow me to change channels nor turn the volume up or down. I think it may be a code problem that is set by the remote, but after changing remotes, the problem remains. I can't determine if it is TV or remote control code related! PLEASE HELP!
We are in the same boat. I think you need a new circuit board that holds the buttons for power, channel, volume, etc(mounted on the front of the TV.) I have not been able to find one yet.
Posted on Dec 28, 2007
6ya staff
SOURCE:
Went black and white rca f32648
so far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also
have you tried following things
1 - playing different dvds (dvd player )
2 - changing different channels ( cable tv or antenna )
3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ]
contrast colour tint black level sharpness
picture presets auto colur colour warmth
4 - auto channel searching ( cable tv or antenna )
even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......
for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model - http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Nov 06, 2011 | RCA F32648 32" TV
I am trying to add channeles to my daughters tv. I picked up a pl9125c221 at a flee market to let my daughter play her wii. the problem is that i can not program the tv to channel 3. when i push the...
So this is a remote for the tv? and does the wii have rca cables still or do you have the single cable that screws in or pushes on? if it has the rca cables the red white and red wires then you should plug those in and on the controller press the TV/Video button. and can you turn the channel to channel 3 for the wii? let me know if this helps if not i can help more.
Apr 17, 2010 | Televison & Video
How do you connect a Nintendo 64 game station with 3 cables (Red,White and Yellow) to a Dynex Television. We tried the input options on the back of the TV. On the menu we selected both Channel 3 and...
connect the AV cable to the red white and yellow input outlets on the tv and press input on your remote you have to be on video 1, 2, or 3 to play the nintendo 64
Dec 26, 2009 | Dynex DX-L22-10A 22 in. LCD TV
Unusable signal
video inputs do not have channels you must not have it on the right source. Turn your Wii on then change the input untill you find it.
Sep 08, 2009 | RCA F32648 32" TV
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
May 06, 2009 | RCA F32648 32" TV
RCA F32648 32" TV DVD Connection
My daughter is having the same problem with the same model tv.. I had a bit of trouble finding the manual for that tv at the RCA web-site --- but I did find it at Amazon.
The URL for the pdf version of the manual is:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000032746.pdf
Assuming you have the remote for the tv, there are instructions in the manual for setting up the relationship between the DVD player and the TV.
(The URL for the TV on Amazon is: http://www.amazon.com/RCA-F32648-32-TV/dp/B000050FZR The link to the manual is toward the bottom, in the Product Details section.)
Jan 07, 2009 | RCA F32648 32" TV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
RCA F32648
if it is a universal remote control , u need to reprogramer
May 02, 2008 | RCA F32648 32" TV
Hitachi VCR and Phillips Magnavox TV
Mentor, sounds like it`s wired incorrectly or your using RCA cables (yellow, red, white ends) out of the vcr into the tv, If your using RCA cables the tv`s "input" (on the remote) has to be switched to "video input 1 or 2" etc to see the vcr tape. If you want to see the vcr`s picture on channel 3/4 you have to tell me if your using a cable or sattelite box and then I can tell you how to wire it with the coax cable, let me know, BMW Rider
Feb 07, 2008 | Televison & Video
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
RCA F32648 32" TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
