NEC Inforntia DX2ET 32 BM (caller ID function not working)
To restore the caller ID function on your NEC Infrontia DX2ET 32 BM PABX system, you can follow these steps:
Check the configuration settings: Ensure that the caller ID feature is enabled in the system configuration settings. You may need to consult the manual or a professional to assist with this.
Check the phone lines: Make sure the phone lines are properly connected to the PABX system and are functioning properly.
Check the firmware: Make sure the firmware on your system is up to date and compatible with the caller ID feature. If not, you may need to upgrade the firmware.
Test the caller ID function: Try making a call from an outside line to the PABX system and see if the caller ID is displayed on the phone. If not, try using a different phone to see if the issue is with the phone itself.
If the above steps do not resolve the issue, it may be necessary to seek the assistance of a professional technician or a vendor who specializes in NEC Infrontia PABX systems. They will be able to diagnose and resolve the problem.
