Question about Blodgett DFG-100 Gas Single Oven
Blodgett gas oven 60-90 sec main b urner goes out
Fans come on, pilot lights, main burner lights. 60-90 sec main burner goews out. same results in 30 sec then 60-90 sec and repeat 30 60-90
    New Friend:
  • 21 Answers
After burner on did you hear any spark ignitor if that your flame sensor is dirty or need to replace....good luck
Posted on May 06, 2014
6ya staff
SOURCE:
Anonymous
  • 254 Answers
SOURCE: power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Posted on Jun 10, 2008
Anonymous
  • 254 Answers
SOURCE: Main Burner not lighting
This is caused by a faulty pilot safty valve. it will be the tee looking valve with the red dime sized button in the middle.
Hope this helps You
please rate me
Posted on Jul 23, 2008
Anonymous
SOURCE: athens controls inc board for old blodgett oven (gas)
Athena still sells this product as a ttc001
call me at 610-729-1032
Posted on Jan 08, 2009
jeffbvegas1
Jeff Barton
  • 520 Answers
SOURCE: Blodgett Oven won't light
you are improving the voltage across the flame sensor . it probably is just short of being in range, failure to meet the proper micro amps the sensor produces will cause lock out and no ignition. sometimes you can simply adjust the sensor to hit flame better and it will work much better...
Posted on Jul 02, 2009
Charles Jerney
  • 12 Answers
SOURCE: My company has Blodgett Gas
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Posted on Dec 09, 2011
Blodgett pizza oven won't stay lot. Pilot stays lit as long as oven is off
Sadly when dealing with GAS I prefer not suggesting any self repairs . call a certified gas repairman .
Sep 25, 2015 | Blodgett Ovens
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
Oven is very sporaditic, will heat up get to temp , go to load mode then shut off. Sometime after an hour or two sometime after 15 minutes
Your pilot light is probably blowing out. If you follow the pilot light gas line from the pilot flame back to the main valve, you will see a screw about the size of a pencil in diameter. If you take that screw out, there is another screw down in the hole you just uncovered. You have to have a very small screwdriver to reach that screw. If you turn the little screw counterclockwise, the pilot light flame will get bigger. A lot of times this will help. If you have a drafty location, the pilot will get blown out and that shuts the main gas valve off.
Sep 22, 2010 | Blodgett DFG-100 Gas Single Oven
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
Feb 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
Blodgett 961-P pizza oven
Go here find what you seek.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Great Co.
Sep 30, 2008 | Blodgett 911-DOUBLE Gas Oven
Won't light up
had the same problem, safety gas valve is sticking get a small hammer and tap saftey valve. Just bought a new saftey valve about 3 weeks ago pilot light lite but now flame. I have a blodgett oven made in the 60s. Blodgett is getting away from there swithes that they have been replacing them with a replaceable thermocouple.made by robert shaw. My supplier said that they are not on the market yet. oops! good luck from oswego ny pizza villa.
May 01, 2008 | Blodgett 911-DOUBLE Gas Oven
Hope this helps You
please rate me
Oct 18, 2007 | Blodgett DFG-100 Gas Single Oven
Blodgett DFG-100 Gas Single Oven Logo
173 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Marvin
Marvin
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
