Regardless of the cycle the dryer will shut off on its own after one minute
A Whirlpool Duet dryer has a latch on the interior frame of the door. It essentially locks the door closed when the dryer is operating to keep you from opening the door and becoming injured by the tumbling drum. The dryer can only run when the latch is secured. If the latch breaks, a dryer might start but shut off prematurely. Open the door and press the latch down with your finger. It should make a ticking sound when you release it. Replace it if it doesn't.
A dryer's power cord delivers electricity from the electrical outlet to the machine. If the power cord isn't firmly plugged into the outlet, it can interfere with the electricity transfer. While your Whirlpool Duet dryer might start, it probably will shut off soon afterward if the cord is wobbly. Also, if cords wires are visible through the rubber encasing, the cord might be defective. Though the dryer turns on, a faulty power cord might not be able to sustain the dryer's long-term operation.
The Whirlpool Duet dryer's control panel operates with the support of multiple wires that link to various dryer components. After you choose a drying setting and turn on your dryer, the control panel begins running elements of the dryer. If one of the wires fails, it can disrupt the performance of your dryer. Contact a dryer repair specialist if you suspect that the control panel might have short circuited. If your dryer is still under warranty, rather than replace the corrupt wire, he might recommend replacing the entire panel.
Unsteady or Damaged Power Cord
Triggered Thermal Fuse
Faulty Control Panel
SOURCE: Dryer shuts off after 10-15 minutes
The motor is overheating and shutting down, cooling down, overheating again. Motors are expensive and tricky to install. PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
SOURCE: Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
