Emerson LC320EM9 32 in. LCD HDTV Logo
Anonymous Posted on Dec 11, 2013
Tv wont get channel signal
I unplugged my TV to hang it on the wall plugged it back in once it was mounted and it says press OK to set channel.....I do then it scans and says the same thing once complete....its hooked up to an HD box which I had reset 3 times and the cable company has said the box is getting a clear signal ive tried it on all tv sources possible and still nothing...any ideas? (tv has maybe75 hrs on it, almost brand new)
Peter Kennealy
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 17 Answers
  • Posted on Dec 11, 2013
Peter Kennealy
Contributor
Level 1:
New Friend:
Night Owl:
Answers
17
Questions
Helped
2886
Points
43
1- Have you tried a different input cable?
2- maybe try using the set top box tuner?
3- check the input setting on TV?
Good luck
3 Related Answers
epik559
Erik Garcia
  • 44 Answers
  • Posted on Jan 03, 2008
SOURCE: Problems with out tv
1-800-256-2487
Elias Pedraza
  • 53 Answers
  • Posted on Sep 01, 2009
SOURCE: sound but no picture using all of my ports
Hello Eweber touch the screen with your finger and see if you can see light behind your finger on the screen if you can this means your backlight is working and the problem is more than likely coming from the inverter board which is faulty and has to be replaced, if you can not see any light this could be a faulty backlight or inverter board, in most cases it is the inverter power supply which turns out to be the faulty one, thank you hope this helps.
Anonymous
  • Posted on Dec 08, 2009
SOURCE: Emerson LD195EMX - just bought from Walmart,
Hey, most stations are not broadcasting analog anymore. That is why you are only getting 10 channels.
2answers
How can I add a channel on a vizio tv?
If you are using an Antenna, Coaxial cable from the wall or a cable/satellite box connected to the TV with a coaxial cable, you will need to do the following steps:
1. Press the INPUT button on your VIZIO remote to view your current input source. Ensure that the TV input is the input that is selected.
2. If the TV input is not selected, press the INPUT button on the remote until the TV or DTV input option is selected.
3. Press the Menu button on your VIZIO remote and select CHANNELS.
4. Select the option that says FIND CHANNELS.
5. Once the scan is completed it will say DONE. Press the OK button on the remote once. This will go back to the channels menu and then you can press the EXIT button to leave the menu.
6. Use the VIZIO remote to change your channels
1helpful
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Trying to setup tv 2, just upgraded the tv from an old school analog set to a brand new phillips 40pfl3705d/f7. can't get a signal on the tv and have tried both "air" and "cable"...
Hi carltonmarcumy name is Mike Houston of DISH Network and for the TV2 you want the Modularset to cable and channel 73, and then make sure the TV itself is set to channel73. After you have the modular set to channel 73 and the TV set to channel 73and you do not see a DISH Network picture you will then make sure theconnections from the wall to the TV are tight as well as from the receiver tothe wall. Then you will want to unplug the receiver for 10 seconds and plug itback in it will power up and acquire the signal and once you see that check TV2and you should see the same thing on the screen. I will send a link that will helpout with these steps. http://www.dishnetwork.com/SupportSection/black-blue-tv2
My television continues to display the phrase "DIGITAL CHANNEL SIGNAL STRENGTH IS LOW" I ahve called the cable company several times and had this checked to see if it was maybe a defective box...
Go to Menu - then channel - then memory channel - let the tv reconfigure the channels. You might need to unplug tv (the light to tv might still be on - press the on button to release the juice). Then plug tv back in. I did this and it worked.
1helpful
2answers
My Haire HL37E is stuck in the multimedia mode and wont respond to anything, what is my solution
get a niversal remote and use the codes for lg not for haier,,, once its programed (turns off/on) press last/channel button that`s it
32helpful
8answers
Vizio 37L suddenly stopped getting all digital channels
I had the same problem with my 42" vizio. Was working fine for about a year and a half, then a month after all stations went digital, I couldn't see any digital channels and it wouldn't scan for digital signals
This is a strange go around, but it worked for me. . Tried unplugging, pushing power button for two minutes... did everything the forums suggest, with no resolve. But, here's what DID work for me. Trust me, it sounds strange, but it continues to work (and, yes... it's not a permanent fix... the channels still go out once in a while, but I can always get them back now)
Use your Vizio remote control. Turn your TV on. Press the "input" button until you get to "RGB", which is what you would connect a computer to. Make sure no computer is connected, or it's at least off if it is connected. When you get to RGB, you'll see a message that says "No Signal". After about 5 seconds, the TV will enter a sleep mode and seem as if it has turned off (orange Vizio logo). Once it completes it's little sleep cycle and "clicks" off, wait a few seconds and hit the input button again. It'll go to the next menu item. Keep clicking input until you're back on "TV", and VUALA! The channels are back!
I accidentally figured this out when trying to troubleshoot, but I'm glad I did. Didn't want to dishout $250 to get it fixed. Let us know if it works for you too!
My dvd shows prog 200 and wont change
FIXED! LG DAT-250W INSTRUCTIONS: TURN OFF THE MAINS POWER AT THE WALL UNPLUG ANTENNA FROM THE BACK TURN POWER BACK ON AT THE WALL & START AS NORMAL IT WILL COME UP WITH "POOR SIGNAL" THEN WE FLICKED THROUGH THE CHANNELS & TURNED IT OFF AGAIN AT COMPONENT & AT THE WALL PLUG THE ANTENNA BACK IN TURN EVERYTHING BACK ON Note: **Just avoid the channel that keeps locking up** LG are aware of this issue
Panasonic PV-C1352W cable signal
They claim that if you leave the set unplug from the wall for about 10 minutes and then plug it back in and ushing the power button the set will auto program all the channels available,Without the remote is possible but not as easy,in the front of the set you have the stop/eject button and the REW button,if you press both buttons at the same time a MENU(display) should come up on the screen,keep pressing action until the CH square is highlighted then use the arrows up or down until antenna is selected the use the arrows left or right to change it to Cable,once is in the cable mode go down one more to auto set and press the arrow to the right and it should auto program all the available channels. I hope I made sense but just in case here is the link to the owners manual http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportResults?storeId=15001 ,it can be done.You can use my name in a new question to let me know how it goes ir if you need more information.
Concierge series 25" wont stay on channel 3
If Im not mistaking , some of Zeniths TV sets cannot be unplugged or disconnected from the wall. It will delete the memory and I guess the default channel is Channel 52.. I didnt know you disconnect the set in the ? you asked before. To stop this simply plug the set into an always on wall receptical and turn on the cable then the TV set. your going to need to do this order of operations as I know Zeniths will detune and you wont get any color sometimes if you turn on the TV then the cable. Sorry nothing you can do short of getting another set. Good Luck
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
