Refrigerators Logo
a
abdul wahid Posted on Dec 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator repair I have everest refrigerator, the plug has burned and refrigerator not working, after changing plug the refrigerator also not working
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Everest Refr... Master 518 Answers
  • Posted on Jun 12, 2016
Marat Brikov
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324529
Points
3123
how burned compressor looks like inside. opened it up.
Luis Calderon
Level 2:
New Friend:
  • Expert 146 Answers
  • Posted on Dec 12, 2013
Luis Calderon
Expert
Level 2:
New Friend:
Answers
146
Questions
0
Helped
38717
Points
303
It probably burned out the relay and the start capacitor on the compressor and maybe the compressor burned out too make sure the condensing coil is clean along with the fan motor on the back of the refrigerator bottom side.
Everest esr1 refrigerator
Yes, it does exist,. It is a commercial reach-in refrigerator.
ESR1 ' Everest Refrigeration
everestref.com > product > esr1
Description. Everest's Upright Top Mounted Reach-In Series offers an outstanding combination of refrigerator, freezer, and dual temperature options as well as full ...
Everest Refrigeration ESR1 29-1/4" One Section Solid Door ...
www.restaurantsupply.com > everest-refrigeration-esr1-...
The ESR1 is a 29-1/4" wide, one-section stainless steel insulated upright reach-in refrigerator from Everest Refrigeration with 1 full-size self-closing and field ... Door Style: Swing
Number of Shelves: 3US$2,176.00 · ‎In stock
Everest ESR1 29-1/4" Solid Door Upright Reach ... - Amazon.com
www.amazon.com > Everest-ESR1-Refrigerator-29-25...
Buy Everest ESR1 29-1/4" Solid Door Upright Reach-in Refrigerator, 23-Cubic Feet, NSF: Refrigerators - Amazon.com ? FREE DELIVERY possible on eligible ...
Everest Refrigeration ESR1 29" Solid Door Reach-In ...
www.therdstore.com > page > IFSES > PROD > ESR1
Shop commercial refrigeration equipment at Restaurant Depot. Commercial refrigerators, commercial freezers, merchandiser or beverage cooler for your ... US$2,175.72 · ‎In stock
Freezer temp set at -4 but temp stays around 26
freezer section not working
get a fridge technician in to check / repair.
1helpful
No power to compressor for everest epr3
Check if there is voltage to the contactor coil...if it is built into the board...then it probably is the board.
2answers
My Everest Freezer, Model ESF1, SERIAL BSF1-0106-0024, is not cooling at all; I can hear the fan working, but inside is warm. Do I need a new control board? what do I need? please advice. Thank...
Hello there,
If your refrigerator is not cooling, but is running perfectly, you will have to test the door switch, defrost thermostat, defrost heater and the defrost timer, when you test them, replace the faulty part and it will work perfectly fine.
If that does not solve the problem, then check the door switch. Make sure you check the refrigerator if it is still having gas in the cylinder. If there is no gas the refrigerator will be working perfectly fine but will never get cool.
Hope this helps. All the best Elect_Comp
Freezer temper 25 (selected -4) 2 deprost not working. 1 is working 1 is not working (inside fan area)
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
The fan working but fezzer and cooler not cool
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
1helpful
Commercial fridge is blowing the fuse in panel all of  a sudden. Nothing has changed. Is it the fridge or panel?
unit could be using more power then normal if it needs cleaned, next time it blows fuse find and outlet that is still working (and not overloaded with other products) plug refrig in that outlet with extention cord and see if it blows that fuse.
Top Everest Refrigeration Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
