Apple Power Mac G5 Desktop Logo
m
micah watson Posted on Dec 11, 2013
Login password - Apple Power Mac G5 Desktop
neurascenic
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Dec 14, 2013
neurascenic
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
5008
Points
48
The solution to this is tricky. and may cost you some money. and, if this is a file vault protected user account, you are just plain stuck. Assuming you want to save all your data read all before proceeding. Get a second Hard Drive, install an OS on it if there isn't already one. Boot to that HD, Set up as "NEW" do not transfer any info. when you get to it, create a user account that is different and obvious from the old account you are trying to reclaim. Use something like "TEMP Account". Copy your user account from the old HD to the new HD (into the Users folder) create a new user account, but use the same name as the old user folder is called. use a password you will remember and add a "hint" at the bottom. log out and log back into the user account that you just created.
The steps I should do for forgetting passwords when I use switches?
This needs to be discussed in different situations, you can check whether these situations can solve your current problem.
Scenario 1: All Default Passwords Are Changed and All Passwords Are Forgotten If you change all default passwords and forget the console port login password, all STelnet/Telnet login accounts and passwords, and BootROM/BootLoad passwords:
·For a switch that has the PNP button, you can press and hold the PNP button for more than 6 seconds to restore the switch to factory settings and restart the switch. The following figure shows the PNP button.
·If the switch does not have the PNP button, return it to the factory for repair.
Scenario 2: Default Passwords Are Forgotten For S series switches running V200R020 and later versions, no passwords are configured for default accounts, and users must configure new passwords for logging in to the switches. In this situation, scenario 2 is not involved.
However, for S series switches running versions earlier than V200R020, there is no default STelnet/Telnet login password, but there are default console port login password, default BootROM/BootLoad password, and default web login password. These default passwords may vary according to the switch version.
If you always use the default passwords and have not changed the passwords, you can obtain the default accounts and passwords according to S Series Switches Default Usernames and Passwords (for enterprise users or carrier users). The permission level of this document is C (customer support level). If you need to upgrade the permission level, see the help document on the website.
Scenario 3: The Console Port Login Password Is Forgotten Three methods are available to recover the console port login password.
·Method 1: Log in to the device using STelnet or Telnet and change the console port login password.
·Method 2: Clear the console port login password in the BootROM/BootLoad menu and change the console port login password.
Scenario 4: The STelnet/Telnet Login Password Is Forgotten ·If you forget the login password of an STelnet/Telnet account, you can use another STelnet/Telnet account with administrator rights to log in to the device and reset the password. For details, see Method 1.
·If you forget the passwords of all STelnet/Telnet accounts but can log in to the device through the console port, see Method 2.
Method 1: Use an STelnet/Telnet Account with Administrator Rights to Log In to the Device and Reset the Password
1.Log in to the switch using the STelnet/Telnet account with administrator rights.
2.Change the STelnet/Telnet login password. The following example describes how to change the STelnet/Telnet login password of VTY0 to VTY4.
Method 2: Log In to the Device Through the Console Port and Set a New STelnet/Telnet Login Password
If you forget the STelnet/Telnet login password but remember the console port login password, log in to the switch through the console port and set a new STelnet/Telnet login password.
Scenario 5: The BootROM/BootLoad Password Is Forgotten but the Console Port/STelnet/Telnet Login Is Available If you can log in to the switch through the console port, STelnet, or Telnet, log in to the switch and restore the default BootROM/BootLoad password. You can obtain the default accounts and passwords according to S Series Switches Default Usernames and Passwords (for enterprise users or carrier users). The permission level of this document is C (customer support level). If you need to upgrade the permission level, see the help document on the website.
Scenario 6: The Web Login Password Is Forgotten but the Console Port/STelnet/Telnet Login Is Available If you can log in to the switch through the console port, STelnet, or Telnet, log in to the switch and reset the web login password. In the following example, the web login user name is admin123 and the password is test@123.
For more reference resources, please click to enter (ebook) CloudCampus 3.0 Solution:
https://support.huawei.com/enterprise/en/doc/EDOC1100201111
OR you can straight to see this decument
https://support.huawei.com/enterprise/en/doc/EDOC1100200698#section1612361212554
2answers
My apple lap top keeps asking me for my key chain password, what is this?
Try using the password for the user you are logged in with? J
How do I change login and password
Hi, there are many things which has a login and a password.for example "www.gmail.com" has a user name and password;Or a computer can have many logins.Each login can have a password.In every thing you can change the login and password using settings or control panel. I WISH YOU BEST OF LUCK AND MAY GOD BLESS YOU
2answers
Forgot login password on laptop
Forgot laptop login password? You can use Smartkey Windows Password Recovery to reset laptop login password, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
2answers
Password recovery steps for lucent dsl max 20 dsl terminator
You have been prompted for the login password and received the following message: “Login Password isinvalid”.• Re-enter the correct password and press enter. Remember that the password is case-sensitive. Check that youare entering admin in lowercase and that the Caps key is not active.• If you have forgotten the password, you must reset the login password. Refer to the User Guide, ChangingConfiguration Switches, and perform the following procedure:1. Move switches 5 and 6 down.2. Type login <newpasswd>. Password checking is overridden.3. Move switches 5 and 6 up.4. Complete any configuration update that caused the prompt for login.5. Change your login password to a new password.6. Store the configuration and reboot the router.Note: If you have not reset switches 5 and 6 to the up position and have rebooted, this will place the router inmaintenance mode. Set switches 5 and 6 up and turn the power off and
www.alliedtelesyneurope.com/media/.../manuals/rg624-34_um_a.pdf
2answers
Telnet password
Use this step:Router>enable Router#config t Router(config)#line vty 0 4 Router-2(config-line)#login% Login disabled on line 66, until 'password' is set % Login disabled on line 67, until 'password' is set % Login disabled on line 68, until 'password' is set % Login disabled on line 69, until 'password' is set % Login disabled on line 70, until 'password' is set Router-2(config-line)#password newpasword
11helpful
9answers
I forgot my Password to the Login of my Laptop
Have your HP laptop login password forgotten? Do you have another administrator? Have you created Windows password reset disk on your HP computer when it is available? Or whether you have installation CD?
If you have administrator, just change HP login account to this administrator and access HP computer with it. At this time, no matter which account, you can easily change or remove its password on Control Panel.
If you have password reset disk, on Windows login screen after you type incorrect password, there will be a message "Reset Password" prompting you to reset forgotten Windows password with reset disk. Just follow password reset wizard to do.
If you have installation CD, it will help you to restore HP computer or repair computer. But it is still dangerous for us to use it because it will delete some important data on your computer.
In consideration of data safe on computer, Windows Password Genius provides a safe Windows password reset environment WinPE. With it and in such password recovery environment, you will don't need to worry about data lost or damaged.
This is a video showing how to use it.
http://www.youtube.com/watch?v=quxuEqpG6f4&feature=youtu.be
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
