Here are the codes for Maytag Ranges:
MAYTAG Type "C" and "D" Clocks Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced.
Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC
F2
Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits.
Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean)
F3
Open temp oven temperature sensor; sounds alarm and inhibits cook mode
Replace oven temperature sensor
F4
Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode
F5
Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode
Replace electronic range control (ERC)
F5
Missing a/c line cycle detector; displays code (no audible)
Unplug appliance for two minutes, should clear problem
F7
Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC)
F8
Analog/Digital supervisory; sounds alarm to non-cook mode
Replace ERC
F9
Door latch supervisory (door latched)
Unlock door and check switches or clock assembly (also called the ERC)
F0
Cancel key supervision
Requires the removal of power until serviced. See qualified technician
