Where they go into
SOURCE: Trying to connect Sharp VCA310X VCR to TEAC TV
I would suggest trying to change the channel, either on the tv or the vcr. Sometimes, if the channel is one off, you will get sound but not a picture. On the back of the vcr, there SHOULD be a switch to change it to either channel 3 or channel 4. You must match this up with the channel your tv is set for. I hope this helps, but if not, I hope you can get it figured out soon. Good luck! Der Strom
SOURCE: I am trying to hook up this VCR to a digital TV
Well I will tell you what the colours mean first. RED is right audio and WHITE is Left audio. YELLOW is Video.
I don't think it will matter if you plug the white or red into white, but the yellow must go into yellow. Is the device with white & yellow mono and not a stereo device? As that would explain why it's not got a red terminal.
Wouldn't it be better to connect via the scart socket, they must have both got one. If you are using the scart on the TV for something else, you could get one of these switching boxes from Amazon.
