Freezer gets cold ,but fridge is not getting cold, checked the flame OK banged the back pipies
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
[email protected]
www.coachtech.info
734 777 6432
SOURCE: My dometic fridge doesn't cool some times but the freezer works
I don't know what type of fridge you have side by side or top mount or bottom mount but what every it is sounds like the air ducts are blocked with ice or the air damper is not working.
SOURCE: Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
