I may be able to help with your Kodak EasyShare Z740 that turns itself
off.
It may be a 'lens extending' problem, or it might be fixed
with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I
hope that helps.
_____________________________________________
Turns Off Fix
Manual Download
Remove the batteries and clean the battery contacts inside the camera
with a soft cloth (a heavy buildup on the contacts may require cleaning
with a fine wire brush, steel wool, or sandpaper). Remove any residue
that the cleaning leaves in the camera, and then reinstall the
batteries. This clears most power-on problems, but if yours persists,
check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
This problem is frequently due to corroded battery terminals inside the
camera. Remove the batteries and wipe the terminals with a soft cloth
(heavy corrosion may require a fine wire brush, steel wool, or
sandpaper). Remove any residue left in the camera by the cleaning.
Clean the terminals on the batteries in the same manner, and then
replace them in the camera. This cures most problems, but if it
doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/r...
It uses a simple Q&A format to diagnose problems and propose solutions.
SOURCE: Have Kodak easyshare Z740 camera, turn on and goes
off.
I
hope that helps.
Turns Off Fix
Manual Download
Mine does exactly the same thing!
