Bosch RotoZip Spiral Saw RZ10 - 2100 Logo
A
Anonymous Posted on Dec 10, 2013
How to replace brushes in rotozip rz20 - Bosch RotoZip Spiral Saw RZ10 - 2100
1 Related Answer
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 04, 2010
SOURCE: I have a rotozip - RZ20. I've been using it
Your speed controller has failed. You will need to get it replaced, brushes do not give, those symptoms.
2answers
Whereto get manual for roto zip z20
The manufacturer's web site has the manuals for many of their tools on their support page: http://www.rotozip.com/en-us/support/Pages/Manuals.aspx . If you have the RZ-20, the direct link to the manual is http://www.rotozip.com/en-us/support/Documents/WEB2610938267%2002-07%20RZ1-25.pdf .
I don't know of a Z20 from RotoZip. I hope this helps.
I have a rotozip rz20. The bearings are shot. Need to know where I can find a new set. Google has not been any help.
http://www.ereplacementparts.com/rotozip-parts-c-15402.html?utm_source=Bing&utm_medium=PPC&utm_campaign=rotozip%20-%20search%20-%20mike Try here.
Jun 20, 2015 • Saws
RZ20 - depth adjustment screw, what does it screw into? I can't get it to tighten to hold in one place. Please help ASAP!
The screw may have been loosened too much and a small plate has fallen out. Have you contacted RotoZip customer service directly?
1helpful
2answers
I was cutting 1/4" wall tile. On the 3rd or 4th cut my rotozip RZ5 quit working. There is power at the outlet. The machine was pretty warm. Is there a fuse or thermal reset or do I need to send it in foer...
I have had similar problems in the past using my Roto-Zip on jobs. You may want to check the internal brushes in the machine have not been clogged with the dust from the ceramic tiles. The unit may have simply overheated from the stress of cutting the tile. This will also affect the brushes in the Roto-Zip. A can of compressed air may help clear any dust built up around the brushes. If they brushes are caked with to much dust, you may have to take the unit appart and manually clean the brushes. But, be careful because the brushes are spring loaded. Hope this information is helpful.
4helpful
My rotozip RZ20 keyless chuck will not open.
open the chuck and look in the center there is a screw allen type most times or a star screw in the middle that connects it to the drill shaft just tighten it up should work fine then!
Top Bosch Saws Experts
NOEL
NOEL
Ngoro
john h
Are you a Bosch Saw Expert? Answer questions, earn points and help others
