My son's ipod tough (2nd gen) speaker played when he got it. Now the earphones work, but not the speaker. He tried to reset it, but can't get the speaker to play.
to update your ipod touch second gen to 4.1 version you must connect to your itunes account on your computer with ipod attatched sync all apps, music, videos, everything because it will delete everything and needs everything backed up. then go to your ipod on itunes and it will say update, click it it will take around half an hour to update and restore you ipod fully. This worked for my ipod touch gen 2, it kept saying when i tried to update i still have things on my ipod not synced to itunes when i have synced multiple times but it updated ok and i do not notice anything missing. this is all i know about this i hope it helps.
Most often, the ear phone might be the problem.try getting a new ear phone preferable, one from another manufacturer,if it does the same way, the problem will be from the earphone port.
Some Pure-Fi's has a problem charging 2nd Gen Touch iPod, even when proper supplied adapter is used. You can try pressing the iPod further into the connector and see if it stays charging. If not, you can tilt the Touch slightly forward to make proper charging contact with Pure-Fi's iPod connector.
If you only charge your 2nd Gen Touch in your Pure-Fi, or other devices less thick than the Touch, like iPod Nanos, then you can stick a spacer on the Pure-Fi behind the Touch to always properly tilt it slightly forward. Only space it slightly forward just enough to cause it to charge so as not to stress the connector.
Stick-on chair/furniture protectors work good for this. If they are too thin, stick one on top the other till you get the thickness you need. Do not use any thicker a spacer than needed so as not to stress the connector any more than needed to make charging contact Use thinner stick-ons, like double sided foam tape, to get the final spacing you need.
The added advantage to a proper spacing between an iPod and Pure-Fi, is it relieves connector stress when plugging in and using an iPod while plugged in, since the taller Touch iPod cannot tilt backward. If you place your spacer at the very top of the Pure-if back panel, then iPods thicker, but shorter, than the height of your space can also be used.
Hope this helps everyone with this irritating Pure-Fi design problem.
To view the charging/not charging status on the 2nd Gen's screen, turn off the 2nd Gen and the Charging Icon will show when contact is being made.
While playing music, the iPod Touch should switch automatically from earphones to speaker when you unplug the earphones. If your Touch doesn't do this, it may have a physical defect. There is no setting on the Touch that would cause this problem.
The internal speaker stopped working on my 2G touch yesterday. I performed a restart on it and the speaker function was restored. Basically just follow the 5R process in this website: http://www.apple.com/support/ipod/five_rs/
The only viable trouble shooting option I have available on this current issue is to restore the ipod touch using itunes. Just in case you are unsure of how to do a restore, I have included step by step instructions below.
try getting new head phones if the new head phones dont work then it is the jack and u need to get it replaced. If it is the new 2nd gen ipod (has speakers on the bottom) u aren't going to want to check the plug it is dangerous to the ipod to take off the rear or front plate because u can damage the screen or wires and u will have even more things to fix.
