Question about Canon DR-7580
Capture barcode at scanner Canon Dr 9080C
I dont know how I can unable the barcode reader in the canon dr9080C
    New Friend:
  • 24 Answers
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001
Then you can select it in Canon's document scanning software/Capture Perfect.
Scan-R-Store
Posted on Jan 18, 2015
6ya staff
SOURCE:
mohanchennai
Mohan Sriraman
  • 490 Answers
SOURCE: Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Posted on Feb 21, 2008
mohanchennai
Mohan Sriraman
  • 490 Answers
SOURCE: Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
Posted on Jun 23, 2008
mohanchennai
Mohan Sriraman
  • 490 Answers
SOURCE: iDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Posted on Jun 30, 2008
Anonymous
SOURCE: Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Posted on Jan 31, 2009
mohanchennai
Mohan Sriraman
  • 490 Answers
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Posted on Jul 10, 2009
How to know the drivers to install on a cpu
Dear sir...
you dont worry about the cpu.you just consider the OS only(Operating sytem).search the barcode driver in google with barcoder brand name with model no.(model no specified in the lable of barcode reader)
Example: free download barcode reader for sanion AG1020 driver for vista
here,
sanion is a brand name,
AG1020 is model printed on barcode reader body,
Vista is Operating system instaled in the computer.
ALL THE BEST SIR...
Dec 04, 2010 | Computers & Internet
How can i get the total number of pages scanned by my Canon 9080C scanner
Click 'Start', 'ControlPanel', 'scanners and Camera', select 'DR9080c' and you will get the count.
S. Mohan
Aug 20, 2010 | Canon DR-9080C Path-Through Scanner
Where to dowload 64 bits driver for Canon dr9080c?
go to the manufacturer site to download the driver
Oct 24, 2009 | Canon DR-9080C Path-Through Scanner
S. Mohan, Chennai
Jun 18, 2008 | Canon DR-9080C Path-Through Scanner
Cannot select a lower bit depth in colour than 24 bit?
With better processors and large storage, higher color depth is the order of the day; however if you dont want higher color depth, you can convert the images after scanning. Ofcourse it requires an addl effort.
May 21, 2008 | Canon DR-9080C Path-Through Scanner
176 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
