control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right
click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or
troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
tried that already. also tried the diagnostcs, but the panel does not respond.
