Camera turns on and eye extends adn then retracts and camera shuts down
SOURCE: Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
SOURCE: Camera will not stay booted up
It seems that the Milli Amps on your rechargeable batteries are to low you will notice on each battery it will show the amplitude purchase a higher amplitude.
SOURCE: camera will not stay on
I have basically the same problem. I sent it in for repairs. It came back and I followed the instructions they came be. BUT IT STILL WONT WORK. it's worse then before, the logo wont even come anymore ! :(
SOURCE: Camera shuts off like dead a dead battery with new ones
Fixing your problem could be as simple as cleaning the battery contacts
in the camera, or the solution could be a lot more complex and
expensive. Here's a link to the Kodak Help Center - it provides a
simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: Camera won't stay on
I may be able to help with your Kodak EasyShare Z740 that turns itself
off.
It may be a 'lens extending' problem, or it might be fixed
with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I
hope that helps.
_____________________________________________
Turns Off Fix
Manual Download
