Hi, well NO, it is NOT a fuse, the reason this set has shut down,
This is a classic switchmode power supply, which is shutting down the set to avoid a fire, explosion, or both. This set has developed a problem, that is so severe that the set must be shut down, This set should now, be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Samsung, in your case. Now, when you get the information you want, from the "Quote" well, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have original parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
below is your user manual.
http://www.retrevo.com/support/Samsung-TX-R3081WH-TVs-manual/id/276bh235/t/2/
