GO ONLINE AND TYPE THE FOLLOWING INFORMATION:
MFG.NAME OFFICEJET J4500 MANUAL
ENTER
WWW.MFGNAME.COM/SERVICE
/ TECH_SUPPORT
/ SERVICE MANUAL
ENTER
ROD
SOURCE: I want a hard copy of users guide for officejet j4500 all-in-one
you can download the guides and manual at the following link
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3645100
Mark
SOURCE: how can i install manual HP Officejet J4500
You can install the printer software both either using the cd software that is included in the package or you can download the software www.hp.com/support. Make sure that you are installing the correct printer operating software. instead of doing a recommended installation choose advance install and uncheck the software that you think that is not needed by you. hp solution center is an important software. also the hp imaging device. but before you proceed in installing make sure that your anti-virus, firewall, spyware are turned off. There are times that the printer software function will not work because it is being blocked by the firewall, spyware and anti-virus. enjoy installing the printer.
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem" etc.) typically indicates the internal micro-electronics
of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire
runs at rear and lower side of the ink cartridge are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on all models which use HP 901 cartridges. Refer to
Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer
Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts -
Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers
Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500
J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP
901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
is this a 4540, 4550 or a 4580 printer?
DO YOU NEED A MANUAL?????????????????????????????????????????????????????????????????????????????????????????
