Zanussi ZBF360 Electric Single Oven Logo
A
Anonymous Posted on Dec 09, 2013
Zanussi single oven
Had power cut,now oven wont heat up
1 Related Answer
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 13, 2008
SOURCE: main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
2helpful
Using grill and everything tripped now grill or oven wont work
Electric grill most often uses heater element to heat up.Maybe your heater elemen is shorted to oven body thus tripping the safety device.
Check your grill system using insulation tester.If the insulation is low check the heater elemen insulation and if defective replace them.
2helpful
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
1helpful
The fan comes on but the oven does not heat up
You need to replace the oven element, this is located at the rear of the oven compartment behind a removeable cover.
A very easy job to do.
Make sure power is off before doing anything.
My oven wont come on and i know there is a problem with the electronic programmer, can i reset it or not use it at all
If you cannot reset the oven timer, then it will not heat the oven.
This being the case, then it is possible in some cases to bypass the timer, or the alternative is to to replace the timer.
2helpful
ZBF360X Electric Single Oven: fan oven working but no heat...
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
Good Luck,
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
2answers
Fan not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
1helpful
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
1helpful
Zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
2answers
Zanussi zbf 760 (9 yrs old now)
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
