SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
SOURCE: pioneer vsx-305 need wiring diagram for this
I have problem with connecting subwoofer to receiver.
SOURCE: Pioneer VSX-D606S subwoofer set up
is the square button also labled as down arrow button, push the down arrow button and will give access to the lcd screen setup options on the receiver center speaker size lfe att settings cross over rear channel size ect. i don't have the manual either took me a year to fix the issue.
