Konica Minolta PagePro 1350W Laser Printer Logo
R
Riley Griffiths Posted on Dec 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1350W HOW TO KNOW IF IT NEEDS CLEANING - Konica Minolta PagePro 1350W Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Feb 25, 2018
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1912491
Points
11959
If you keep it clean yourself that print much keeps it clean use your op manual to check for required maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
White streaks on every printout
Pull all imaging units out and clean the laser with the wand provided either in tray or on front door.
I'm getting vertical streaks from my konica minolta 1350W laser printer. I've read it's the charge wire that needs cleaning, where is it located and how do I clean it? thanks
Hi
You can find this wire on the front side of the drum assy. You can check near the drum it is known as Corona wire which passes high voltage to erase the drum making it ready to receive the next image. You can clean if with a ear swab without any cleaning liquids. And also do remember that sometimes there is an Blue color tab on right or left side of the toner which moves hence you can clean with it as well. Its been given for the same purpose.
Regards
Lost the CD for 1350W installation. Need to find the driver and anything else that needs to be downloaded to make it work. Can you help?
The drivers can be downloaded from this link below.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=979&filetypeid=0&osid=3
Utilities can be download from this link.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=979&filetypeid=5&osid=3
Robert from Blitware
2helpful
I need a driver for a 1350W to run in Windows 7 (64). I'm thinking maybe a Vista 64-bit might work? My brand new 8 Gig Elite is without working printers!
I have this printer in the attic coz of vista. konica minolta did not bother to create a driver for VISTA. I brought out the 1350w not that i got win 7. still no driver.... i have a feeling there wont be a 1350w driver for win 7. however they have 1400w drivers for vista/7.
the only way you can print with the 1350W is as a remote printer in win virtual pc running xp.
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
Konica 1350w will not pick -up paper any more? please help?
I had the same problem. I noticed there is a ridged rubber wheel that picks up the paper and it was just sliding over the paper. I opened the printer, pulled the toner cartridge out and rubbed the wheel with my finger until I could feel friction. Closed it back up and it works. Perhaps the rubber wheel gets coated with paper fiber and makes it less "sticky" over time. A simple cleaning may be all it needs.
2answers
Refill toner konic minolta 1350w
hello
i just installed a new cartridge , but i still have vertical streaks on my sheets
do i need to get the toner clean , and what product do i use ?
thanks again for you time / help
2answers
Konica pagepro 1350W
There is no cleaning sequence for the 1350w. I usually just pull the toner unit out and clean the roller, etc. Compressed air for the moving parts and hard to reach places. Best to do it outside.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
