My phone needs charging and when i plug it in to charge,it starts and then stops the charging process ! it is now very nearly flat.This problem has only started today.
SOURCE: Charging the battery on Samsung Upstage sph-m620.
Well if it's new, then I would take it back to the store from where you bought it. It will be under warranty so, if something is wrong you should be able to get it swapped out with a working one.
SOURCE: My Samsung Propel won't charge!
I had this same problem and ordered a new charger from ebay. It charges fine now.
SOURCE: Samsung SGH D807 Charging Problem and no screen display
Have you try to use another similar charger to charge your phone to see if it ill charge? because it could be that your charger is bad,. But if you have done that and it is same thing, it means the charging port of your phone is malfunctioning, that is why you have to use repetitive effort before it can charge.
Your battery is not charge due to the bad charging port of your phone, so your phone battery can not hold charge.
To resolve 1 and 2 problem of your phone, all you need to do is to change the charging port of your phone in other for your phone battery to charge and for your battery to charge.
Replace the charging port as said and you will see that your phone battery will charge.
For your screen, is it that the entire screen is black that you cannot see anything, not even text or see names from your contact? if it is, what you need to do is to change the flex on the the screen of your phone and you will see that your screen will display as you want it.
Take care.
SOURCE: samsung flight will not power on - battery charged
The problem is a software problem.
All you have to do is to flash the phone with the appropriate software and cable.
The phone will be in good condition again.
Take care
SOURCE: Phone will not charge. Says
FWIW Battery isn't the issue every time. Had the phone gotten wet?, which was what started my problem. In my case, the battery isn't the reason for the message. Battery will charge from another phone, and when that phone's battery is install the same message results. Switching chargers fixes nothing, and so far no one has a solution, over the last year. Phone works correctly. No other issues, otherwise.
