Trying to set temp on a Honeywell RT2300B1012/A thermostat. temp is set on 65 and on hold. Tried to set to 75 and hold but reverts to 65 within seconds. Dos not appear to be user friendly.
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
