SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
SOURCE: my goodman gas furnace flashes
it s black square above the gas valve with two wires on it and two tubes going in to it
SOURCE: Our goodman furnace igniter trys to kick in, but
it sound slike the presure switch is not working , if it is not lighting try jumping it out it may work some times you can fool it in to working
One thing all of have to remember is that there is no one fix - for example went to one tonight that had this same problem - when I checked there was no power to the hi limit and if the rollouts trip ypu have to reset them (this tells you there is a problem and get if fixed, the problem here was a bad connection at the molex plug sso code flashes are idot lights to tell you THE AREA of the issue they are not the telltale problem if your hi limit trips it could be a clogged filer with no air flow cut the wire to the hi limit they will still be a 4 flash code and the problem is different
