How to Setup DCS-5220 IP camera
SOURCE: IP camera keeps resets itself
Hi
I have a pretty good knowledge of these cameras as I have 5 around my house.....
IP address resets are likely caused by the default address being loaded (192.168.0.99) and the box is not checked to reset the IP on reboot. You have two options.....
Using IP surveillence, open the camera settings. You will be prompted that the recording will stop, just press OK. Once you get to the settings window, you should see your list of cameras and the config screen for the one that is highlighted. Pick the camera you want to change the setting for and go to the tab where you can assign the IP address and gateway. Type in the IP address you want it to use. Uncheck the box that says 'reset IP on reboot'. That box is at the top. Hit apply. Once you do that, cycle the power on the unit leaving it off for at least 10 seconds. When the camera reboots, type in the new IP and you should be able to view it. (sometimes the camera will default on that IP if your router is using 192.168.0.1 and DHCP for computers that has that IP in it's range of assignments of IPs. Telling the camera which one to use and telling it to not reset on reboot will make the new IP stay in the camera.)
Your second option is to use the Installation Wizard or IE, find the camera either by typing in the IP for the camera in IE with the http:// or linking to the device with the installation wizard. If you follow the same procedure of assigning the IP and unchecking the box on reboot like described earlier, this should cure your problem. You do NOT want the IP resetting on reboot unless the camera will not link to your home router (likely causes for this is the IP range the router uses, say 192.168.1.1 like most belkin or linksys routers use, does not cover the IP range of the camera in it's DHCP server.
What I found best was to buy a junk router, set it's DHCP IP range to cover 192.168.0.99, set the camera, save it, kill the cameras power, connect it to the router you plan to use, then start the camera back up. Make sure whatever IP address you use on the camera is one covered by the DHCP server list on the router. ie: camera is set to 192.168.2.2 and the router assigns IPs from 192.168.2.2 through192.168.2.254. If your router only assigns IPS from 192.168.2.100 through 192.168.2.200 and the IP on the camera is 192.168.2.2, you won't be able to connect to it.
Hope this helps
SOURCE: download software
You can download the driver from the following link :
http://driverscollection.com/?file_cid=390169192057c4f19a60c24a889
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
SOURCE: How to set Static local IP Address for D-link DCS
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
SOURCE: Inability access from other computers
One of the problems of viewing the cam from an office is your office firewall. Make sure that the ports you are using are open in your office network.
Once you have chosen the ports to use, do the following:
1. Change the ports in your camera setup to use the new ports that you have selected.
2. Configure port forwarding for HTTP and RTSP in your router and modem
If you have multiple cameras, you must use a different port number for each camera AND configure port forwarding for each camera
SOURCE: how to setup aztech router
Install the installation disk of the ipcamera. Configure the ipcamera base on your requirements. Then install the ipcamera on the position you require.
