Aprilaire 600 Humidifier Logo
j
james doyens Posted on Dec 09, 2013
Error code r1 on humidastat
If I try to turn the humidifier nothing comes on, when I turn it to test after a bit I get the error code r1
2 Related Answers
Anonymous
  • 232 Answers
  • Posted on Sep 13, 2009
SOURCE: aprilaire 760 humidifier. no power to humidastat
the 760 send power out the humidistat is just a switch if you touch the two brown wire coming outof the 760 the humidifier should come on if it doesnt and you had appiled power to those wire you probably shorted the 760 control board
Dan Favata
  • 233 Answers
  • Posted on Nov 25, 2010
SOURCE: Hello! Humidifier quit working. Turned dial to
if you hear a "click" at the unit when you increase the demand for humidity it could be a clogged solenoid valve. If you heart nothing this could indicate a power problem. turn the humidistat to the highest setting and verify the proper voltage is available at the solenoid, if so, the solenoid needs to be replace. hope this helps.
Dan
The night light turns on, nothing else works.
check the humidastat, its the setting on how much humidity you want . your supposed to turn on to high speed for a couple of minutes and then switch to low to keep filter wet. the humidity level will affect the on and off operation. other than that test the plug with another appliance such as a lamp to see if plug is good, the night light will work for awhile without power for some reason.
Hello! Humidifier quit working. Turned dial to test and nothing. Usually I hear the humidifier working if I increase the dial to a higher level but nothing. Could it be the solonoid is gone? Thanks!
Dan
I replaced the water panel on our aprilaire 600 humidifier. I adjusted the thermostat to call for heat to test it. When the dial (non-digital control panel for the humidifier) is turned to test/reset,...
Thank you for contacting us with regards to your model 600 Humidifier. The Change Water Panel indicator should flash when the control knob is set to the Test/Reset mode. The flashing indicates that the timer has been successfully reset. However, the humidifier should operate for the first 60 seconds of Test mode as long as your furnace is running. If your humidifier does not turn on, contact your installer. The humidifier may require service.
We appreciate the opportunity to be of assistance.
Sincerely,
Brett Phillips
Technical Support
Research Products Corporation
What is the purpose of the sailswitch
The sail switch is in the cold air return it is wired in with the humidastat when your furnace goes on the air movement pushs the sail down inside the duct work that makes a contact the lets the 24volts to the humidastat. If the humidastat calls for moisture it turns on the humidifier but only when the blower on the furnace is on So in short it detects air movement
1helpful
No water going to furnace humidifier
The furnace should be equipped with a #50 relay to turn the Humidifier on and off when only when the furnace blower is on. You should have a test mode on your humidistat. Do you have water coming up to the solenoid valve? Make sure that the saddle valve is turned on to supply the water to the humidifier. Is your humidistat set high enough to turn the humidifier on? Is it plugged in?
Good luch
HVAC Teacher
Aprilaire #224 celinoid not opening, water not flowing
it may be kickin on but you dont get water there is an metering device {little piece of plastic with hole} that cuts down on waste water it may be clogged to see if it is opening take a screwdriver and see if when humidastat is trying to work that you have a slight magnetic pull on the opposite end where water lines go
Aprilaire 760 humidifier. no power to humidastat
Aprilaire 550 humidfier not getting water
Is there 24 volts coming from the humidastat to the solinoid?
Constant water flow
I have the same problem with a Aprilaire 760. I'm guessing it's a bad solenoid but want to hear that from someone who can confirm this.
Top Aprilaire Humidifiers Experts
Paul Carew
john h
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
