I am trying to burn my football games from both back up folder and direct dvd. Power Cinema will only let me burn 50 files at a time. 1 game is way more that 50 shots. When I try to burn the rest of a game on another disk, I get error code FF030C00. I don't know what that means and I don't know where I could find what that error code means. I want to know how i can burn more files at a time on to one disk and how I can burn files using an entire disk instead of a small fraction of disk space.
Error Code FF030C00
I am trying to burn some stuff and I keep getting this error message. FFOS2102. What does that mean?
I am looking for a solution to my software problem when I bumped intoyour query and right after that a possible solution.
Here is the link... I hope it works
http://www2.cli.co.jp/products/ne/update_everioM7SD/pcm4e_update.htm
this one allows you to make 98 insted of just 50..goodluck
SOURCE: error code FF030C00
Thank you for the suggestion. I tried 3 different DVD types DVD +R, -R & RW I found that I only get the error on the DVD +R
SOURCE: Tried to burn a DVD using Power Cinema by going
means you have a faulty or failed DVD burner (error is Power Calibration Error, returned through the ATAPI driver). Test with different /branded/ blank media, if none work then replace the drive.If you find one that works, stock up.
Yes I have the same thing
i have the same problem ,i couldn't burn my dvd because it let only 50 shots...how can i do ?...
I have 1 hour of recording which is about 3000mb.That should easily fit onto 4.7 Gb disc.Why it is asking me for at least 4 discs to be inserted?
JVC charges us "an arm and the leg" how about at least telling us about this 50 file only problem, that everyone seems to be having..
trying to burn disk get error code ff030c00 what do i do to fix it?
I also get the error code FF030C00 constantly and have NO idea what this error code is for. I am lucky if I can burn one disk out of 20 try's. Please, help!
