How to turn the volume up on 2.4 hz
Since you didn't give the model of your VTech 2.4GHz system I can only answer in general terms. On most models you can turn up the ringer volume by pressing the up-arrow or + key while in standby mode. You can turn up the speaker volume by pressing the up-arrow or + key during a call.
If you need a manual, enter the model number into the search box at http://www.vtechphones.com/support/general/manuals
SOURCE: Low battery
You need to buy new batteries for your phones. Large retailers charge $10-12 per battery but you can usually find them for closer to $4 online at amazon.com or eBay.
SOURCE: working one set of Vtech 6041 cordless phone set with another?
I have the vtech dect6.0 with one answering system and two remote docking systems.I can phone out from the remotes but cannot receive incoming calls from the remote.When I pick up the remote to receive the phone immediately shuts off.
SOURCE: my Vtech 5.8 cordless phone says ringer is off.
press and hold menu button. Find ringer, push up button to change ring volume.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
my vt phone is lock and need to unlock it help
