There is no water coming into the machine I need to reset it
The first thing I would check would be the screens located where the washer hoses connect to the machine . Shut off the water and carefully uscrew the hoses. You may get a little water leaking from the hoses when you unscrew them but that should stop shortly. After removing the hoses inspect the screens located where the hoses were connected they can get plugged with sediment and can slow or stop the flow of water into the washer. Clean them off with a small brush( an old toothbrush works) . Before reattaching the hoses run some water out of them into a pail to flush any remaining dirt or sediment that may be in them. Reattach the hose and see if that works. If it still wont fill it may be a faulty solonoid valve. To replace this I recommend a appliance repairman.
reset
