SOURCE: Cannot unlock Uniden BC60XLT-1 (30 ch VERSION)
if all the channels are 000.000 then it wont scann youll have to hit manual then enter a freq then hit the "e" button. once you hit manual youll be able to push the up and down arrows to select an channel you wish to imput a feq. Hope this helps.
David
SOURCE: 1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
SOURCE: channels locked out
Mrs. Santa brought me a new PRO-97 yesterday. I'm new to this - just wanted an aircraft frequency scanner, but got the whole shameal. I had a bad AC adapter and attempted to fix the power problem as directed in the manual by re-initializing the scanner. That blew all memory away.
I received the feared All Channels Locked Out message and through a little research and fiddling, realized the scanner was pre-programmed. An Addendum came with the scanner with instructions to reload the 155 pre-programmed frequencies:
1) Turn off the scanner and then turn it on again.
2) When 'Multi-system Trunking Scanner' appears, press PGM.
3) Press 1.
This will reload the pre-programmed frequencies erased by the re-init. Press scan and it'll be as new as outta the box!
Best wishes,
Farnk
SOURCE: Uniden UBC92xlt
foursons, have you tried resetting the scanner yet. On pg 47 it mentions about turning banks of channels on or off. Possibly some banks got turned off. Resetting the scanner starts on Page 53.
I hope this helps somehow, and good luck with it,, Mechanic
SOURCE: I have a uniden ubc73xlt handheld scanner,can't
Try a master rest:
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
