Dell Inspiron 6000 Notebook Logo
Posted on May 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inspiron 6000 power goes on and off
Inspiron 6000, power on/off if a/c jack wiggles
can problem be fixed without entirely repllacing motheroard?
Anonymous
Level 3:
  • Master 700 Answers
  • Posted on May 12, 2009
Anonymous
Master
Level 3:
Answers
700
Questions
Helped
268945
Points
2031
Could be your battery is already dead. If it will be suddenly off then can be turn on again.Check your battery if it still can hold charge. It could be you are actually just running on AC source.
Hi my dell inspiron 1520 not starting when power button is switched on..the power light blinks and goes off..and the system doesnt start. I had shown the laptop ito dell service center and they have...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
But, if you paid for the Dell service, Dell needs to fix the problem. Sounds like they replaced the motherboard with another faulty one.
Hope this helps.
tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 • Computers & Internet
2answers
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
2answers
I need to replace power jack for Dell inspiron
Better to call Dell technical support for this issue. They're the only one that can provide on your issue. Thank you.
How do you fix or replace a faulty power jack for inspiron 6000?
I PERSONALLY DONT THINK THAT ANY DRIVER IS GOING TO HELP YOU REPLACE UR POWER JACK,YOU WILL HAVE TO GET TO AN I T SPECIALIST,CAUSE UR JACK WILL HAVE TO BE REPLACED,AND IF YOU TRY AND DO THIS YOU WILL VOID THE WARRANTY ON THE MACHINE
Problems with the AC jack on back of Dell Inspiron 6000
there is a small metal inside the dc socket that you need to pull towards the centre so i makes better contact with the charger
Dell Inspiron 6000, charging AC problems
This sounds as if the jack in the machine is loose or broken. Take a small screwdriver, place it in the jack, and see if there is any play in the jack. If there is play then you know the jack is loose/broken. I would suggest checking it or having someone check it. A loose or broken jack can create an electrical arch that can do severe damage to the machine, so if it is the jack, you will want to get it fixed ASAP. I also suggest not using the machine, if possible, until the jack is checked out. If it turns out not to be the jack, then it's going to be a problem with the power management system, and this is a major fix. From what you've posted, I'm going to say that it's the jack, and repairing the jack will fix your problem. If you have anymore questions feel free to ask.
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
3helpful
3answers
Dell Inspiron 2200 loose DC power pin connector
hi, the power jack must be removed by a strip out and de solder of jack and a new one fitted. I was lucky a guy took £30 for the job.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
