SOURCE: canon imagerunner Ir c3200 total reset
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
SOURCE: RESET IR 2018 AS FACTORY DEFAULT
Additional Functions button>ID System Settings>Initilize All Data Setting tab. This may take a while to process do not power down during this time.
SOURCE: Canon IR 2020 Error E007
THE PROBLEM IS WITH THE FIXING FILM, IT HAS A SENSOR ON ONE SIDE THAT IS WERE THE FILM IS TORN. REPLACE THE FIXING FILM
