It fills very slow and just won't spin
Hi Miguel, I am happy to assist you!
I understand your washing machine is taking a long time to fill. Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your appliance. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
SOURCE: my washer won't stop filling
I have a Maytag that had that problem. Mine has a plastic tube inside of the machine that connects to a sensor. As the water level rises, some of it goes into this tube creating air pressure on a sensor that signals the machine that the water is at the selected level. The bottom of the tube had come loose and just needed to be put back onto the fitting. I accessed this tube by lifting the top of the machine, and it is in the back. Very easy to get at. I hope this works for you.
SOURCE: Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
HIm this is a faulty timer control. simply replacing this device will fix this issue.
CLICK HERE
SOURCE: Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
SOURCE: Washer will not spin for
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
