Onkyo TX-8211 Receiver Logo
A
Anonymous Posted on Dec 07, 2013
There no sound coming suddenly the amp and all buttons are working fine power as well only no sound
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
My 96 Taurus GL has an electrical short somewhere, The radio works on & off , the defrost is out,The speedometor works only every so often, when the lights are on it starts giving me a clicking sound...
sounds like you may need an alternator... theres not a short< your just losing battery power and the steering wheel being hard to turn is probably your engine cutting out... also it could be a seized up pully or a/c compressor...
My rear and center speakers suddenly quit working. No sound
try a different source. if there is output on all speakers in test mode, then the amps are good but the source or source switching may have a problem.
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Marantz amp will not put out any sound
If it went out with no indications of trouble it's probably a fuse in the output circuit. It might be an out put amp but typically they let you know they're going bad with a little noise.
2answers
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
JL 1000/1 Amplifier
mine did that. i cleand the battery wires and hook ups now it works fine.
Power & protect
my amp says Lo on the digital circle on top of the amp i have a mtx 9500 bridged to the amp and it cuts out at high volumes and suddenly please help
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
