LG KU990 Viewty Logo
A
Anonymous Posted on Dec 07, 2013
How to turn off gang image mode
My two year old managed to turn on gang image mode on my phone, how do I turn it off?
How to fix fatal error
In order to fix your phone, you need to be calm and patient. Make a wrong move and no one will be able to help you.
Method A) First thing to do is determine if you can connect your phone to your computericon1.png and open its file-system up. If you can, just replace the files that you messed up with the original files (If you didn't back-up get the files above) and then restart your phone.
Method B) If you cannot access your file-system because your phone is constantly rebooting, the first thing you need to do is turn your phone off. If the on/off button doesn't work, pull the battery out to turn it off (DON'T TURN IT ON). Then connect your phone to your computer (While its off, and it should turn on by itself and go into a charging screen) and see if you can access your phone's file-system, again if you can replace the messed up filesicon1.png, and restart your phone.
Method C) If you STILL can't access your phone file-system, don't fear there's still hope. Some users have reported success using this method, but it may or may not work for you. Try holding all 4 buttons (camera, lock/unlock, and volume rocker) on the side when the phone is starting, see if you can get it to a white screen with information stating "This phone has the IMEI. If you want to make the gang image erase the IMEI," if you see that, connecticon1.png your phone to your computer and replace the files, then restart.
Method D) If you find that you cannot stay in the gang image screen above, meaning it turns blue/black with error fatal when you connect to the phone, then do this: Remove the SIM card out and turn on the phone. Hopefully you will get the emergency call screen to display (where you can only make 911 calls). Connect to your phone now and replace the files.
__________________________________________________ _________________________________________________
I also got the fatal error screen and another way to get it to the gang image screen is to remove your sim card and leave the battery in then plug it into a wall charger and then use the four button thing to take it to the gang screen, after it gets there unplug it from the wall charger and plug it into the data cable and the screen will remain at the same position..
This is Basically a Factory Reset for your phone. Try the other solutionsicon1.png above, then go for this one. Kind of a..Last Resort i guess you could say.. This is also known as the "GrCobb Method"
I had the same type of problem and had trouble resolving it by putting back the files I thought I had changed. I was getting LG's 'blue screen of *****' with a message like Fatal Error: Dog: 1 or something like that. Here is what I did:
1. Downloadicon1.png the LG Vu firmware files from this site (http://www.lg-vu.com/index.php?topic=3902.0). Unzip it. These files contain the entire LGAPP firmware folder. Then unzip it. It should create a LGAPP directoryicon1.png with every file that was on your phone when you got it. I know DH said to not replace the entire LGAPP folder because it may brick your phone but, hey, it's already bricked so not a problem.
2. Get into EFS and connect with your phone. Get to the gang screen on your phone using the steps if you have to.
3. Rename the LGAPP folder to something else (LGAPP_bad). Do not delete it. There are some files that are read only and you get an error message replacing them when you copy the new GAPP on top of an existing LGAPP directory. This doesn't happen if you rename the old LGAPP to LGAPP_bad before you do the copy.
4. Copy the LGAPP directory you unzipped above to the phone and restart it.
That is what I did and it came back to a clean state as if you did a factory reset.
Hope that helps.
I am trying to wire a three gang box that has 15 amp power into it which has a porch light a outside light and a out side plug. i have a black and red comming in which is hot.how do i connect this...
Copy following links:
http://waterheatertimer.org/How-to-wire-switches.html#gang
http://waterheatertimer.org/images/3-gang-box-800.jpg
You have to test which wire is neutral.... usually white wires twisted together and covered with wire nut in back of box.
Hot wire with test 120volt to neutral.
Hot wire will test 120volt to ground.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Unable to read mode. It remains in recording mode whatever mode I select.
After years of use these wear out just like anything else, if the camera is 10 years old it is going to cost you more to have it repaired than it will cost to replace it. 10 years is a long time, and the price for repairs will be sky high.
How to connect three gang switch to control three lights, using two 1mm double core
What is 1mm double core?
Following image shows example 120Volt 4 gang switches with outlet.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
Each 120Volt electrical box has one Hot wire. This is true for ceiling and wall boxes.
Normally in a gang box, the Hot wire jumpers across all devices in the box.
Some switch boxes do not have Neutral wire. Neutral wires are usually white, and are twisted together and covered with wire nut and shoved to back of box.
Open following links for typical 120V and 240V circuits in US.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Feel free to add a comment and describe wiring, and voltage.
For example if hot wire arrives from one of the lights.
Describe the wires that you have, and what each wire goes to for best possible answer.
How do i wire a 3 gang switch
Open following links for images of 3-gang and 4-gang single-pole switches.
With the 4 gang, just subtract one of the switches.
http://waterheatertimer.org/images/despard-500.jpg
If you have a 3-way switch, or outlet in the box, then add a comment with more exact information about what wires you are trying to connect, what color wires you have, and what you have tried so far. This will narrow down the possible answers and speed help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
5-year old 32 in. Samsung which only displays a fuzzy gray image
It sounds like the T-CON board problem, you can try reseating the connector first, the board is mounted under the metal shield which sometime can be difficult to get to.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Camera turns off in "play" mode
The problem probably is not the camera but the memory card. It 'happened to me, try replacing the memory card or clean with degreaser spray the pins on the card and, if you can, clean the contacts inside the camera (with caution).
Ciao
GIAVAR7
Ascolta Trascrizione fonetica Dizionario
  1. pronome
    1. io
3helpful
2answers
LG viewty doesn't turn on!
If you know that the phone is having problems with software:
Turn on the Gang image mode on. Do this by holding the red phone button + C + green call button + lock button at the side of the phone. Hold all these buttons at the same time so the screen becomes yellow saying "Gang image mode".
Next download EFS explorer onto your computer, connect your phone with the USB cable. You should be able to access your phone. There are other sites which tell you what to do more clearly.
http://www.mygreatphone.com/ - go to forums and find your problem
I have the LG Vu and the screen keeps going to Emergency download
hi your ph dispy strip is broken so change this at reparing shop
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
