Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
Posted on May 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Having problems connecting a lap top computer to the internet.
We have a Gateway (model #MT3705) laptop computer. We are trying to get a wireless internet connection. The computer prompts are asking for network security settings. What are the network security settings for a Belkin wireless router?
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on May 11, 2009
Anonymous
Expert
Level 2:
Answers
56
Questions
Helped
34942
Points
178
Connect the router directly via lan to your computer.
goto setup of the router: usuallly via the ip-adress of your router (see manual, usually: 192.168. ***.*)
Now look at the network security-settings .
Lap top wireless connection to internet router
you need to turn on the wifi button on router
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
1helpful
I have a model W350A lab top and i was having problems with vista so i uninstalled and then reinstalled it on my lap top and now i cannot connect to wireless internet. My lab top came with a built in...
You need to install the wireless drivers.
All the Gateway W350a drivers are available from here: http://rapidshare.com/files/106560686/drivers_laptop_gateway_w350a.rar which has a free download option.
My gateway netbook will not connect to the internet. it keeps saying limited or no connectivity but the wireless connection i have it on is perfectly fine
mcdevito75 here, Sounds like you have 2 sourses of internet, if so, your wireless is connecting to sattelights just fine while the connection built into your lap top is slower.
IS THIS LAP TOP WIRELESS
yes , it have a built-in wireless
Just bought a new lap top have a wireless router on my PC but want to connect to the internet on my new lap top which is wireless enabled, it has picked up the router which is still named as default but...
From your PC (not your laptop):
Click START
Click RUN
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Find the line stating "gateway 192.168.xxx.yyy"
Start Internet Explorer
Type http://192.168.xxx.yyy
Login to your router
Click the "wireless configuration" button
Set a new security-key or passphrase.
Now, try connecting wirelessly from your laptop, using the new security-key or passphrase.
Inacees to internet and no sound after installing Vista on my lap
Do u have the drivers for Your Laptop if so install them usually the sound problem is due to the improper or no installation of the Drivers
My wireless laptop gateway won't connect to my router again after going out of town using it at hotel and now it wont connect at home. it will connect on my job with no problem
Hi!
It is possible that the wifi networking where you connect in the Hotel use the same name of you home wifi network!
Try deleting your wifi profiles and reconnect again.
If you don't know how to delete the wifi profiles let me know and I tell you.
Thanks!
Wireless in Mexico
Wireless connectivity is the same everywhere in the world. The biggest problem you are likely to run into in Mexico is finding a wireless signal to connect to. The better hotels should have internet connections, but Mexico is not "wired" like the USA is.
Your laptop should be able to connect to any unsecured wireless signal anywhere. I suggest you try taking it with you next time you go downtown in your area, and experiment with finding wireless signals. College campuses are a great place to find wireless, as well as having lots of students who are used to connecting to wireless all over town, who might be willing to help you connect.
The icon you need to use to find a wireless signal can be found in the little bar next to your digital clock, in the lower right corner of your screen.
Connection problem
The first thing to check is that both of your computers are assigned to the same workgroup name. Right click 'my computer' and select properties. Change the workgroup name so that they are identical on both machines. You will need to reboot if you change the name one one or both of the machines.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
