SOURCE: Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
SOURCE: motor rund but drum dont spin
Fluid Drive clutch greasy or worn,
Pump blocked or drive belt too loose
SOURCE: Speed queen Marathon top loading washer-
The problem is the water inlet valve has failed. There is a video on checking this at www.appliancehelponline.com/servicemanual.html it's a different model but the testing procedure will be the same.
SOURCE: Oil/grease leaking into tub. Speed Queen
Check to see if the oil is coming from under the agitator. If it is replace the transmission. If it is not check to see if there is a grease spot inside the was tub.
