Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
You should have no issue focusing as that beep is just an in focus confirmation. I never use it as it wastes battery power, along with other items that can be turned off in the menu system such as do not show pictures after taking one, no illuminated focusing zones, no grid lines, etc.)
The beeping on shopriders usually means that the Main Control Box is faulty. It may also be caused by the Throttle Pot being out of neutral. This is a common promlem on this model of scooter as they use a Plastic throttle control lever instead of a metal one. Unfortunately, the plastic one's sometimes slip round slightly causing the above problem. Throttle pots can be very difficult to set to neutral without a multimeter so may be best left to you local dealer.
replace with a new card. The beeps are indicitive 0f failed hardware 2 beep 2 beeps = video card series of 3 beeps keyboard ,malfunction etc etc so whichever card now gives you one long beep you had better start there.....
