I have done searches for this and found older model region free codes, but none of them seem to work. Can you help me find the right code and what exactly to do to make it region free?
To remove the region code on your Samsung F5550W Blu-ray player, you can follow the steps below:
Step 1 Power on Samsung Blu-Ray E350K, the make sure to remove disc in the tray.
Step 2 Now, close tray. the screen should says "no disk"
Step 3 Press the BLACK button BELOW the yellow "C" button.
caution: by mistake if you press the repeat A-B button bellow the green "B" button, these instruction will not work
Step 4 Press 7-6-8-8-4 (or your region code).
Step 5 The current region code will display at the top left of the screen.
Step 6 Press 9 to change to free region.
Step 7 Power off using the Samsung remote, then Power On using the Samsung remote
Step 8 Repeat steps 1 to 4, your region code will now show a "0" on the top left corner.
Alternatively, you can use Leawo Blu-ray Copy to remove region code on your discs, so that you can play them to any Blu-ray players.
If you can't change the region code on your Samsung player, you might want to consider creating a region free copy of your Blu-ray/DVD discs so that you can play the disc on your Samsung player. There's a program called Leawo Blu-ray Copy you can use to create region free copies of your Blu-ray/DVD discs. A region free disc can be play on any DVD players. Here's how to use the program: How to Make 1 1 Disc to Disc Blu ray Backup with 1 Click Blu ray Copy...
There seems to be useful info here:
http://forum.videohelp.com/threads/342271-Samsung-HT-D6750w-Region-Free
SOURCE: Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
SOURCE: unknown disc for all region 2 discs for samsung ht-x30
First your DVD player has to reset, by pressing stop and play botton simantaneously, and then try 84269
SOURCE: I need to reset the region code on a samsung home
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray.
1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
2. Reconnect to mains
3. Turn on player with remote.
4. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2
6. Press ENTER on remote. (The tray will open and player will power off and close tray.)
7. Switch on power from remote.
8. Player is now Region Free.
Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: Sammi Jones must be an Indian spammer on FIXYA --- samsung HT x20 region code
For Samsung HT-X20 the region code unlock listed workd perfectly. Just hit 8,4,2,6,9 then ENTER (do this twice) and it will play your DVD which it did not before.
Abe
SOURCE: samsung ht-x20 unlock codes
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problem.
Swapnil
