Question about Craftsman 6" Bench Grinder with Lamp
Craftsman 6" bench Grinder Model 319.19062 Manual
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: need manual or pdf for manual
I have the manual you are looking for
Posted on Jun 24, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: I need a replacement switch for a craftsman 1/2 HP bench grinder
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Posted on Dec 28, 2009
Testimonial: "Great solution. Yhank you. - b"
drallim
  • 4088 Answers
SOURCE: How do you tighten the nuts when changing the
Clamp the shaft behind one wheel with 'Channelock' or 'Visegrip' pliers, then tighten both nuts. Check the new wheels for 'off-center' running by spinning them with your hand. They may fit the shaft tight enough that there is no centering adjustment--use a 'wheel dresser' (either a stone type or a multi-wheel type) to true up the wheel so that there is no radial wobble. Hope this helps!
Posted on Oct 23, 2010
4CR-20-756
I need a 4CR-20-756 Klixon relay for a bench grinder.
Oct 18, 2011 | Craftsman 6" Bench Grinder with Lamp
No control of speed on bench grinder,need schematic
Unless the motor is a brush type universal unit, there is commonly no way to change the speed of an induction motor. There are AC motor speed control units available, but cost more than the grinder as they change the frequency as well as the voltage. There are speed controllable grinders available that use brushes so that simple electronics can control speed. Hope this helps!
Dec 08, 2010 | Craftsman 6" Bench Grinder with Lamp
I have a 1/3 hp motor with a capacitor. There are four motor leads coming out of motor, the capacitor is mounted in the wiring box. This motor does not have a centrifugal switch, to isolate the capacitor...
I am in the process of replacing a capacitor on a Craftsman 6 in 1/3 grinder, 2.8 amp, single phase, 110v. Not sure on the centrifugal switch. model 319.190621, ser B9530. When I took the old one out the black wire from the capacitor went to the cluster of back wires (in my case 3) in the wire nut. The blue wire from the grinder went to red wire from the capacitor in a wire nut. Hope that helps you....
Maybe you can help me... the specs on the capacitor burned off when it failed. Can you tell me what the capacitor specs are on yours?
Nov 16, 2010 | Craftsman 6" Bench Grinder with Lamp
How do I remove the wire brush form a model 9410 grinder?
An ajustable wrench for the 'wire brush end' nut,and a visegrip type plier for the opposing wheel end. Wrap the jaws of the visegrip pliers with tape to protect the spindle opposite the wir wheel. Loosen the nut on the wire wheel end,counterclockwise.REMEMBER: lefty loosey-righty tighty.
Jul 22, 2010 | Craftsman 6" Bench Grinder with Lamp
Model 397.19471 need switch but can not find. please help? 8 inch bench grinder
Call the Sears Craftsman help line they will have the parts you need
Apr 02, 2010 | Craftsman 10" Bench Grinder
Craftsman manual for Model 21126 6" grinder
What do you need a manual for? It's a grinder, grind something!!
Sep 09, 2009 | Craftsman 6" Bench Grinder with Lamp
Need manual for craftsman bench grinder model # 257.191300. misplaced other one. hope you can help. mike
Mike
Not sure what was happening when the previous reply was created, but the owners manual is part number 211260001 $7.99 at SearsPartsDirect.com
That said, I'm staring at my own copy of the the owners manual and I can't really see why you would want to pay for one. The only really useful information is the parts diagram which is online at SearsPartsDirect.com. The rest is generic grinder information (support workpiece, select proper wheel, etc.) and CYA (always wear gloves and eye protection, don't remopve safety guards, don't use damaged wheels, don't stick your finger in the light socket, don't cross the steet in the middle of the block, etc.)
Jun 07, 2009 | Craftsman 6" Bench Grinder with Lamp
Craftsman 6" Bench Grinder with Lamp Logo
1,500 people viewed this question
Top Craftsman Grinders Experts
Oliver Street
Lawrence Oravetz
Vernon Taylor
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
