Televison & Video Logo
M
Mollie Johnson Posted on Dec 06, 2013
I have the codes that were sent to for my remote control now I need the instructions how the numbers can be entered
I need the instructions to the setup to enter the code to my remote. Basically, I need the manual with step by step instructions to know what buttons to push when entering the codes. Thanks, Mollie
I need to link my new remote to my television & have lost my instruction manual
If you have a new remote control for your television and you don't have the manual, don't worry. You can still try to link or program the remote to your television by following these general steps:
  1. Identify the brand and model of your television: Look for the brand name and model number of your television. This information is usually located on the back or side of the TV itself. Knowing the brand and model will help you find the correct remote control codes for programming.
  2. Search for remote control codes: Most remote controls come with a set of codes for various television brands. Without the manual, you can try searching for the remote control codes online. Many websites and databases provide lists of codes for different TV brands.
  3. Entering the codes manually: Once you find the code for your TV brand, follow these steps to enter it into the remote control:a. Turn on your television. b. Press and hold the "Setup" or "Code Search" button on the remote until the indicator light turns on. c. Enter the code for your TV brand using the remote's number buttons. The indicator light should turn off if the code is entered correctly.
  4. Test the remote: After entering the code, try using the remote to control your television. Test functions like power on/off, volume, and channel buttons to see if they work correctly. If they do, the remote control is successfully linked to your television.
If you don't have success with the first code you find, try other codes for your TV brand. Sometimes, multiple codes are available, and you may need to try several before finding the correct one.
If the above steps don't work, it's possible that your remote control uses a different method for programming. In that case, try searching for the specific programming instructions for your remote control model online. Manufacturers often have manuals and programming guides available on their websites.
2helpful
2answers
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
1helpful
I lost the papers that tells me how to set it up sony rm-v210 remote control
Here ya go. Heres some brief instructions and a link to sony for the codes and full instructions
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the SET button until the SET indicator lights up.
  3. Press the appropriate component select button for the component being set up.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENTER button.
  7. Point the remote control at the component and press the POWER button.
NOTES:
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • The operation of a combination deck of any kind is not guaranteed.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
go here for more information http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV210
PLEASE SENT ME ASAP THE PROGRAMMING INSTRUCTIONS FOR THE 538744 REMOTE CONTROL [email protected]. thank you. asap!
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Thanx
Need code numbers to program remote control.
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Magnavox TV's are: 0054, 0706, 0030, 1454, & 1254.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
I need code for my Tv
try one of these codes 003, 013, 012, 030, 046, 050, 051, 049 here are some instructions
  2. On the remote control, press and hold the SET button.
  3. While holding the SET button, press and release the POWER button
  4. Release the SET button.
  5. Press the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  7. Press the ENT button.
  8. Point the remote control at the component.
  9. Press the POWER button to verify operation.
NOTES:
here is a link for your remote controller http://esupport.sony.com/perl/model-remote.pl?mdl=RMV302#instr
2helpful
2answers
Codes
try the following codes until one of them work:
002, 003, 004, 005, 006, 007, 008, 044, 045, 046, 053
  2. On the remote control, press the SET button.
  3. Press the appropriate component button for the component being set up.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
NOTES:
I need the codes to operate a sony HT-DDW660
001 is the only code listed for sony
here is a link for any code you might need in the future
NOTES:
20helpful
3answers
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
