47 inch gray screen flickers between main menu screen and gray screen with static sound .just flickers back @ fourth help
SOURCE: lg 42lb1dr tv cuts off no picture or sound. gray screen.
There are 4 capacitors on the power supply board that need to be replace. They are in the same area, same color, look for bulged caps.
SOURCE: flickering white line across top of vizio 47
I had that problem on my Vizio 37" and my new Vizio 55" and now after reading the solution of adjusting the HV position in the setup menu, the problem is fixed! Thank you!!
SOURCE: Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
